11-30-2009 12:48 PM - edited 03-06-2019 08:46 AM
I can't seem to get ddns to attempt to work. 'debug ip ddns update' shows nothing. Here's what I have:
ip domain-lookup
ip name-server 192.168.1.2
ip ddns update method DynDNS
HTTP
add http://username:password@members.dyndns.org/nic/update?system=dyndns&hostname=password@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a> remove http://username:password@members.dyndns.org/nic/update?system=dyndns&hostname=password@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
interface Dialer1
ip ddns update hostname myhost.dyndns.org
ip ddns update DynDNS
Any clues? I don't get any activity.
12-03-2009 01:55 PM
Hi, it looks like some details are missing in your config, and not sure if you are using your user/password.
config t
HTTP
add
http://dataserve:Darahope@members.dyndns.org/nic/update?system=dyndns&hostname=
example: add
http://horizonsit:cyv6tiko@members.dyndns.org/nic/updatesystem=dyndns&hostname=kytc.dnsalias.net
interval maximum 1 0 0 0 ----> (dd/hh/mm/sec)
exit
int fa0/0
ip ddns update
Applying the configuration is :
interface Ethernet1
no ip ddns update DUM_Eth1 host 127.0.0.1
exit
ip ddns update method DUM_Eth1
HTTP
rem
http://172.16.59.2/cgi-bin/dns/
add http://test:test1@members.dyndns.org/nic/update?system=dyndns&hostnametest1@members.dyndns.org/nic/update?system=dyndns&hostname
Please note:
test is your username given from your ddns server
test1 is your password
members.dyndns.org = the url of the ddns server
For you to be able to type the "?" symbol please use: control v ?
For this to take effect we need to shut and no shut the interface.
Useful commands/ debugs to verify the configuration
show ip host-list
show host x.x.x.x where x.x.x.x is the ip address of (say) members.dyndns.org
show running-config | incl host-list
show ip ddns update
show ip ddns update method
Hope this help.
12-03-2009 03:08 PM
What I have actually ended up working. But for some strange reason I have to actually reboot the router (maybe just reset the interface but can't do that since I'm doing it remotely) to make changes to ddns. So, upon enabling ddns I have to reboot and to even change the URL I have to reboot also. So, my working config in it's simplest form is like this:
ip ddns update method dyndns
HTTP
add http://username:password@ members.dyndns.org/nic/update?system=dyndns&hostname=
interface Dialer1
ip ddns update hostname myhost.mydomain.com
ip ddns update dyndns
