02-23-2014 07:45 AM - edited 03-07-2019 06:22 PM
Hi everyone,
So just out of the blue, one of my 2950's stopped working. It's one in my home lab, but still...
I can connect via console cable, but the switch doesn't accept any keyboard commands.
I can see the full boot sequence, and if I plug in/unplug a cable, I see the log on screen, but I can't telnet, or reset the SSH password due to it not accepting any commands from the keyboard.
I have 2x other 2950's and 3x 2611's and they all work with the same console cable.
Any ideas? Is it dead??
Thanks!
02-23-2014 11:15 AM
Matthew,
It may be that the Rx circuitry on the console port of your switch is fried - in that case, you're probably out of luck.
There is a slight possibility that you have configured no exec on your console port, causing it to not start a command interpreter when you hit Enter. Can you actually try to perform the password recovery procedure and see if the keyboard is accepted at least in the bootloader mode?
If entering commands in the bootloader mode, do not use TAB, arrows or Ctrl-Key combinations because they are not supported, and will always cause a command to be unrecognized. If you make a typo, delete the whole line up to the typo, correct it, and type in the remainder of the command again.
Best regards,
Peter
02-23-2014 11:28 AM
Thanks very much Peter.
I've tried the password recovery procedure, but it also is suffering from the same problem, but thanks for taking the time to answer. Looks like I need to look for a new switch
