dealing with switch 2900 IP addressing
the problem is that I have a switch 2900 xl seires and I can not make a telnet to it
in my network the management vlan is vlan no 6 so i had to assign ip address to the interface vlan 6 on that switch
I did that but it remained shut down despite being manually configured to be up
when I use interface vlan 1 it responded but the telnet yet didn't work
i need a suggestion
Bronze
Re: dealing with switch 2900 IP addressing
Have you configured your VTY lines with password and login commands.
VTY LINES are needed to be configured for telnet connection
Raj
Hi Raj,
yes ofcourse i configured vty lines and set the password but the problem still exists
i think that the problem is related to the fact that i set interface vlan 1 as the management interface whereas it should be interface vlan 6 which i can not configure on that switch
You must be connected to the switch on a port in VLAN6.
HTH,
Mohammed Mahmoud.
Purple
If you have a management vlan and also have other different vlans assigned to this switch your uplink has to be a trunk link in order to do this . Also the 2900 has to be a newer 8 meg box versus the old 4 meg 2924's which would not support trunking.
122
