Webcast-Catalyst9k
Dear friends i have a issue with cisco 1200 acess point ,autonomous access point
whenever i connect the access point in the network i could not connect the access point using the GUI interface,but when i connect the access point using the cable from my pc direct to access point i can easily connect using GUI ,
So please can some one help me in this regard i have this issue ,i am not getting solution,.
for the reference i am also copying the run config from my access point.
version 12.4
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$2ggM$rSKvqdqz2qCnaAMK1rGcB.
enable password 7 094F471A1A0A
no aaa new-model
dot11 syslog
dot11 ssid tadrees-ap2
   vlan 2
   authentication open
   guest-mode
dot11 network-map
username Cisco password 7 072C285F4D06
username admin password 7 14141B180F0B
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 key 1 size 40bit 7 E087398FE03F transmit-key
encryption vlan 2 mode wep mandatory
ssid tadrees-ap2
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption vlan 2 key 1 size 40bit 7 A782F312341F transmit-key
ssid tadrees-ap2
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.2
no ip route-cache
bridge-group 2
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 10.10.2.12 255.255.255.0
no ip route-cache
ip default-gateway 10.10.2.200
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
VIP Purple
HI Mohammed,
Please follow this config and check it.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008055c39a.shtml
Hope it helps.
hi sandeep if you read what i mention above in my discussion ,i configure everything,when i connect pc directly to access point i can access gui,but when i connect access point in the network and try to connect using gui from pc i cannot,
and i can even ping the access point but i cant access the access point using gui .
VIP Purple
What version of IOS  u have on AP??
version 12.4
Silver
What is the configuration of the switch port the access point is connected to? Is it an access port or trunk port?
John
dear john,
please if you dont mind can you explain me what if configured trunk port,or access port ,that will playe role in  access the gui interface for the access point .
207
