DECIPHER CSS CONFIG
lamav
Level 8
Level 8
Folks:
Im a CSS-retard, so I need some to decipher this config for me. It doesnt have t be line-by-line, but at leat something close to it.
You know...like explain "circuit" config"...or "service" config...
I just need to make sense out of this config. I do understand CSS principles pretty well, just never configured one.
HELP!!! :-)
NYTAR777-CLB04# sh run
!Generated on 05/25/2009 11:06:52
!Active version: sg0810107s
configure
!*************************** GLOBAL ***************************
prelogin-banner "login-banner"
virtual authentication primary tacacs
virtual authentication secondary local
snmp community YE!@ZP72 read-only
snmp community BXL*%5K] read-write
snmp trap-host 138.69.6.10 public
app session 10.36.48.249 15 authChallenge S1lv3rf1sh! encryptMd5hash rcmdEnabl
e
app port 30666
app
logging commands enable
logging buffer 10000
tacacs-server 10.36.217.3 49 10 TaCaCS2004 primary frequency 255
tacacs-server 172.22.0.1 49 10 TaCaCS2004 frequency 255
tacacs-server authorize config
tacacs-server authorize non-config
tacacs-server account config
tacacs-server account non-config
ip route 0.0.0.0 0.0.0.0 10.36.48.254 1
!************************* INTERFACE *************************
interface 1/1
bridge vlan 717
interface 1/2
trunk
vlan 718
vlan 719
vlan 720
vlan 721
vlan 722
vlan 777
default-vlan
interface 2/1
isc-port-one
interface 2/2
isc-port-two
!************************** REPORTER **************************
reporter VRRP_MONITOR
type vrid-peering
vrid 10.36.48.250 17
vrid 10.36.50.125 20
active
!************************** SERVICE **************************
service nyvector_1_443
ip address 10.36.50.1
protocol tcp
port 443
redundant-index 5
keepalive frequency 30
keepalive retryperiod 10
keepalive type ssl
service nyvector_1_80
protocol tcp
port 80
keepalive type http
redundant-index 3
active
service nyvector_2_443
ip address 10.36.50.2
protocol tcp
port 443
redundant-index 6
keepalive type ssl
service nyvector_2_80
redundant-index 4
protocol tcp
port 80
keepalive type http
active
service ping_VLAN720
keepalive frequency 2
keepalive retryperiod 2
redundant-index 2
keepalive type script ap-kal-pinglist "10.36.50.1 10.36.50.2"
active
service ping_slf01
ip address 10.36.48.254
keepalive type script ap-kal-pinglist "10.36.48.254"
redundant-index 1
active
!*************************** OWNER ***************************
owner acs
content nyvector_443
vip address 10.36.48.1
port 443
protocol tcp
add service nyvector_1_443
add service nyvector_2_443
redundant-index 2
advanced-balance sticky-srcip
active
content nyvector_80
protocol tcp
port 80
add service nyvector_1_80
add service nyvector_2_80
redundant-index 1
active
NYTAR777-CLB04#
THANKS!!
8 Replies 8
Jon Marshall
Victor
A service as in "service nyvector_2_443" is a physical location for content so
protocol tcp
port 443
redundant-index 6
keepalive type ssl
is a server for HTTPS with IP address 10.36.50.2.
The content is as in
port 443
protocol tcp
redundant-index 2
active
in effect configures the Virtual farm and references the physical services. So in the above users would connect to 10.36.48.1 and be load-balanced to either one of 2 physical services - nyvector_1_443 or nyvector_2_443.
Under the content is where you can define the type of load-balancing used, stickiness for the sessions etc.
The owner i must admit has always slightly confused me. Technically it is just the name of the person owning the contents.
Does this help ?
Jon
It helps plenty, Jon.
Funny though, that was the part of the config I was not TOO unclear about. The part that I am REALLY confused about is something I forgot to post. :-)
************************** CIRCUIT **************************
circuit VLAN717
description "VIPs for Internal Web Server DMZ"
ip address 10.36.48.250 255.255.255.0
ip virtual-router 17 priority 95
ip redundant-interface 17 10.36.48.251
ip redundant-vip 17 10.36.48.1
ip critical-service 17 ping_slf01
ip critical-reporter 17 VRRP_MONITOR
circuit VLAN720
description "TSS PCI Internal Web Servers"
ip address 10.36.50.125 255.255.255.128
ip virtual-router 20 priority 95
ip redundant-interface 20 10.36.50.126
ip critical-reporter 20 VRRP_MONITOR
Would you say that this CSS module is configured in bridged mode?
I would say it is in routed mode as the physical servers are from the subnet 10.36.50.0/25 whereas the VIP's that are used for these physical servers are from the 10.36.48.0/24 subnet.
So the CSS must be routing between the VIP subnet and the physical subnet that the servers reside on.
As for circuits -
"A circuit on the CSS is a logical entity that maps IP interfaces to a logical port or group of logical ports, for example, a VLAN." ie. int this case it's just how you can define vlans on the CSS.
Jon
Jon, this sucks, man...i thought by looking at an SLB config I would be able to figure it out....its tough...confusing...seems like theres a zillion combinations....
frustrating...
If the CSS is running in routed mode, is it doing the inter vlan routing between the server VIPs and the real addresses?
"i thought by looking at an SLB config I would be able to figure it out."
I sympathise because it's not that easy especially as the CSS uses counterintuitive terms such as service, context, owner etc. To my mind the CSM terminology is far more logical - guess that's because the CSM is Cisco's own whereas they purchased the company that produced the CSS.
Basically if the VIP's and real addresses are out of the same subnet then you are looking at bridged mode. If they are different you are looking at routed mode. The CSS is indeed handling the inter-vlan routing for vlan 717 and vlan 720.
Note that the following lines -
interface 1/1
bridge vlan 717
simply allocates interface 1/1 into vlan 717 ie. it is nothing to do with bridging in the sense we are talking about.
Don't feel too bad about this config, i don't fully understand it all and like i say the terminology is a lot simpler on Cisco's own load-balancers.
Jon
Jon, I guess whats hard i sunderstanding the many many ways that the LBs and FWs can be connected....so many choices and variations.
Id love to see ONE implementation that comes with a drawing and the configurations for EACH device. That would help me understand...not just tid bits of info or overarching theory, but an actual implementation...
Victor
Victor
Unfortunately i don't have access to old design docs i did for our virtualised DC. You may have seen this doc but it provides useful information on the different setups you can deploy using FWSM + ACE. Bear in mind that the same considerations apply to standalone ASA or ACE devices -
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/ACE_FWSM.html
Jon
something funny....when I telnet into the CSS, the output is screwy.
I get output text on the far left and then on the far rght. Its a "word wrap" issue, Im sure, but I dont have this problem with any other device, except this CSS.
Any ideas?
