Community Member
Default Configs
I wasn't sure where to post this...sorry if this isn't the correct place.
I'm hoping someone can direct me to a one stop location where I can search, download and compare default configs to the templates that we use.
Re: Default Configs
Hi Tim
Do revert on what do you meant by default configs ?
Are you pointing out the factory default config ?
regds
Community Member
Re: Default Configs
What is turned off or on per the default settings in the config. For example, for a 2950, is "no TCP-small-services" a default detting or does it need to be specified? I'm looking for a resource where I can access the specific device default configs. I could obviously bring each device up with default settings and copy them, but I'm looking for a resource where I could just print them or search through them.
Community Member
Re: Default Configs
Community Member
Re: Default Configs
This tells me the typical path I need to follow for most devices, so I'll search along those lines (2811 & 1841). If there's one I can't find, I'll let you know. I appreciate it very much.
127
