02-18-2012 02:02 PM - edited 03-07-2019 05:01 AM
What is the purpose of these default configuration lines? What do they mean? I can't find an explanation of them anywhere. I believe some are written to the config when FCoE is enabled....
I would like to know exactly what they are doing.
class-map type qos class-fcoe
class-map type queuing class-fcoe
match qos-group 1
class-map type queuing class-all-flood
match qos-group 2
class-map type queuing class-ip-multicast
match qos-group 2
class-map type network-qos class-fcoe
match qos-group 1
class-map type network-qos class-all-flood
match qos-group 2
class-map type network-qos class-ip-multicast
match qos-group 2
system qos
service-policy type qos input fcoe-default-in-policy
service-policy type queuing input fcoe-default-in-policy
service-policy type queuing output fcoe-default-out-policy
service-policy type network-qos fcoe-default-nq-policy
02-18-2012 02:43 PM
If you move this to the server sub-forum, Lucien Avramov can probably provided you good feedback. He is the expert and the TME for the 5K series.
Reza
02-19-2012 12:52 PM
Hi, Reza. I'll take your advice.
02-19-2012 02:26 AM
This is default QoS config on n5k devices.
It maps certain qous-groups to different types of traffic and allows you quickly change QoS configuration for these qos-groups to reflect your network needs.
These lines can be easily replaced with your own config.
Here is a qos config guide for n5k
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli/QoS.html
HTH,
Alex
02-19-2012 12:51 PM
HI, this link does not explain everything....it does not address the class-map type qos...type queing...type network commands....I wish someone can authoritatively tell me what each one of those lines is doing - line by line.
02-20-2012 12:33 AM
Here is more detailed link
Please read carefuly docimentation on QoS before doing any confguration on the device.
The following predefined policy maps are used as default service policies:
Type network qos policies can only be configured on the system qos attachment point. They are applied to the entire switch for a particular class
Type queuing policies are used for scheduling and buffering the traffic of a specific system class. A type queuing policy is identified by its qos-group and can be attached to the system or to individual interfaces (except for Fabric Extender host interfaces) for input or output traffic.
Type qos policies are used for classifying the traffic of a specific system class identified by a unique qos-group value. A type qos policy can be attached to the system or to individual interfaces (including Fabric Extender host interfaces) for input traffic only.
So following lines matches traffic marked with certain qos-group to system defined class-maps:
!maps traffic with qos group 1 to default class "class-fcoe"
match qos-group 1
!maps traffic with qos group 2 to default class "class-all-flood"
match qos-group 2
match qos-group 2
match qos-group 1
match qos-group 2
match qos-group 2
system qos - section where system qos policies are configured - they are applied to all interfaces by default
!lower you can see system policies
!applies qos (marking) policy-map for input - this will affect all interfaces by default
!applies queuing policy on icomming traffic
!applies queuing policy on outgoint traffic
!network qos policy applied to entire switch
Basically standart policy structure is
!creating class to which we will map traffic which falls in certain criteria
class map type X CLASS_NAME
!some criteria (ip address, protocol, cos)
match CRITERIA
!creating policy map which will MODIFY some traffic flow characteristics
policy-map type Y POLICY_NAME
!configuring class-map under policy maps meaning that this policy map will apply to all traffic matched by thic class-map
class CLASS_NAME
!applying changes
bandwidth ...
etc..
