08-16-2007 08:06 AM - edited 03-05-2019 05:56 PM
Question, I have a 3560 switch with 1 G0/0 enabled, 1 serial port with a subinterface. I have configure the both ports and the default gateway yet, when I do a sh ip route I received the following error Default-Gateway not set. I've even tried to use the actual ip address. I still receive the same error any suggestions?
interface Serial0/0/0
description ISP Circuit
no ip address
ip access-group 10 in
ip access-group 10 out
no ip proxy-arp
encapsulation frame-relay IETF
clockrate 2000000
interface Serial0/0/0.1 point-to-point
description connected to Internet
ip address x.x.x.x
no ip mroute-cache
frame-relay interface-dlci 384
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0.1
or
ip route 0.0.0.0 0.0.0.0 X.X.X.X
08-20-2007 07:27 AM
Thanks for you asistance on this...I appreciated your comments... Always good to have someone jump in.. I'll let you know when I can get this back online to test..
Again Thanks.........Ernest
08-20-2007 07:21 AM
Ok, That may be it... I hope so however, I never tested or tried the sho ip route command on a box that was/is not physically connected to anything. Which started me asking why the Gateway would not set? That would hold true of a layer one issue.
However, when it was physically connected to the network I couldn't or did not see it as well. So, I had the SA take it off to troubleshoot and this is where we are.
I'll have not made any changes to the config since it was removed....again puzzling that this id the only box I'm having this issue.
08-20-2007 07:35 AM
Ernest
I have tested this many times (and experienced it live more times that I wish to remember) and I am very positive that when an interface goes protocol down that any static route which is configured to use the interface will be withdrawn from the routing table.
The first thing to do is to restore connectivity on the serial interface (and its associated subinterface). I suspect that this will restore the default route to the routing table and establish a Gateway of Last Resort. If it does not then we can troubleshoot from that point.
Rick
08-20-2007 08:02 AM
Will do and I'll let you know..
08-20-2007 06:22 AM
ip routing enabled.
Still get message "Gateway of last resort is not set?"
08-20-2007 06:26 AM
Ernest
I do believe that the output of show protocol, show ip interface brief, and of show version would help us to understand this issue much better. Can you post them (If you are concerned about revealing the IP addressing then I suggest that you just alter the first octet of each address - to something else in that same address class - so that we will not see your real addresses but will be able to understand the relationships of addressing).
Rick
03-10-2020 05:59 AM
I had the same issue on a Cisco router ISR1001-X
ip routing command resolved the issue
03-10-2020 09:24 AM
Thank you for sharing your experience with this type of problem. My observation is that if adding ip routing to the config solved your issue then you were not having the same issue as the original poster. It was quite clear that the problem for the original poster was that the serial interface was not connected and that is what prevented the default route from being added to the routing table. Your post is a good reminder that when investigating an issue where a route is not present in the routing table that it is always good to check and see if ip routing is enabled.
