Community Member
deffer retranmission/ unknow protocol drops on 2960 switch
We got lots of unknown protocol drop when doing show interfaces on the switch.
FastEthernet0/1 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 2c3e.cf28.5c81 (bia 2c3e.cf28.5c81)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:20, output 00:00:01, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 11
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 87000 bits/sec, 50 packets/sec
  5 minute output rate 254000 bits/sec, 302 packets/sec
     767449482 packets input, 166535462190 bytes, 0 no buffer
     Received 574674 broadcasts (567299 multicasts)
     2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 567299 multicast, 0 pause input
     3139071591 packets output, 396765272750 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     245020 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
checking out NMS, we also see deferred retranmission error on all interface of the switch. As this switch used to connect ip phones, it cause voice quality degrade. Any idea/ advise?
dangquangminh@vnpro.org CCIE#11897 6016 Tillsdows Dr, Mississauga,ON Canada L5N4M3
70
