Delete VRF stuck in progress
mhv000001
We have a Cisco 3925 and I am trying to remove some VRF's from the configuration, I have yesterday tried to use the command:
no ip vrf VRF_name1
I have then today tried to use the same command, and the information I get is:
% Deletion of VRF VRF_name1 in progress; wait for it to complete
Do I need to do anything else to get the VRF removed?
Reza Sharifi
Hi.
Possible bug in the IOS you are using that doesn't allow you to use the same VRF name again..
Open a ticket with Cisco TAC to help you remedy the issue.
InayathUlla Sharieff
Totally agree with Reza.
I found the bug i would request you to kindly raise a TAC case to get the bug details.
Inayath
*Plz rate if the info is usefull.
mhv000001
Thanks for the feedback, I will try to create a TAC case for the error.
mhv000001
I have created a tac case about the problem, and they have found out that the problem still persist in the newest IOS, they have created a bug and the developers are looking into the problem.
