Deleted flash:
Hi All,
I have mistakenly deleted flash:
I am on switch: mode how do i come out of that and load the new IOS.
any help will be much appriciated.
many thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Deleted flash:
Since you need to upload the file via xmodem (read: VERY SLOW). I recommend getting the smallest .bin available in CCO and get the device back into a running IOS. Once you have a running IOS, you can use .tar
.tar files are bigger in nature and you need to get this device up and running.
Deleted flash:
Deleted flash:
Hi Edison,
Thanks for your prompt reply.
its cisco 3750G. would it take only .bin wot about .tar ?
many thanks.
Deleted flash:
Deleted flash:
when i try to send the file it says "No response from remote system"
Deleted flash:
Deleted flash:
Hi Edison,
I tried that but no luck same error
any other suggestions ?
many thanks
kamran.
Deleted flash:
Try playing around with the Baud rate in Hyperterminal
Change console cable
Try rebooting the switch one more time
Try with another workstation.
Deleted flash:
I try changing the Baud rate but it doesnt change.shows me the same Baud rate when i check.
many thanks.
Deleted flash:
maybe you could try boot from usb as Leo Laohoo mentioned in https://supportforums.cisco.com/thread/2213270?tstart=0
Hall of Fame Super Gold
Deleted flash:
Won't work, Thomas, because the appliance is a 3750G and this model doesn't have a USB.  The only method is via XModem, as what Edison has recommended.
Deleted flash:
I tried this command but it doesnt work:
copy xmodem: flash:c3750-ipservicesk9-mz.122-55.SE1.bin
gives the follwoing error:
many thanks.
Deleted flash:
Kamram,
When you entered the command "copy xmodem: flash:c3750-ipservicesk9-mz.122-55.SE1.bin" what else did you do?
Did you do this:  From the top of the HyperTerminal window, choose Transfer > Send File.
Deleted flash:
yes i did that.
Deleted flash:
My machine is on the network does it make any difference ?
Deleted flash:
Kamran,
Are you using a USB-to-serial?
Deleted flash:
no its normal console cable
Deleted flash:
This error message means the computer where the IOS is stored is not responding or sending the file.
Try a different computer.
Deleted flash:
Leo,
I will try if i could find any machine to try.
Just a quick one why it is not changing the baud rate ? after changing it when i chek it its the same.
many thanks.
Deleted flash:
Did you use this command:  "set BAUD 115200"
Note the word "BAUD" has to be entered in ALL CAPS.
Deleted flash:
thanks it has changed:
but i could see the "baud=9600" as well which i changed it before when i issue set command.
does it matter to have this or how do i remove it ?
many thanks.
Deleted flash:
To remove, the command is "unset BAUD".
It's all up to you.  If you maintain the default value of 9600 then it'll take, A MINIMUM, of 5 hours to push the BIN file.  If you set the baud rate to 115200, then it'll likely take 55 minutes.
Deleted flash:
I could see two values:
baud=9600
BAUD=115200
is it ok or i should remove the first one ?
many thanks.
Deleted flash:
Hi All,
I have tried on the different computer and i have also change the console cable but still the same error.
any help please
many thanks.
Deleted flash:
Hi all,
Thanks guys its working now.... had to change console cable
thanks everyone !!!!
regards,
kamran.
Deleted flash:
Glad to hear your problem is solved. Please mark the thread as such.
291
