Community Member
Dell Blade Centre & 3750G Stack & NIC Teaming
Having strange problems with a Dell Blade Centre & 3750g stack.
Dell blade centre has two network modules in. One module is patched into one 3750, the other into the other 3750.
NIC teaming is configured so that primary NIC is in one 3750, secondary is in the other.
In standard running all works fine, however when we pull all the network cables out on one module to simulate failure traffic does not appear to be transmitted via the secondary NIC.
I know the above is quick & dirty, however if anybody can help with the following questions that would be great :)
1) Is using Dell NIC teaming on a 2 unit stack supported in smart load balancing mode?
2) If yes to above what gotchas do I need to check for?
3) If no, what options are open to me?
Thanks!
David.
121
