Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Devices on switch
Good All
How do I check what devices are plugged into my switch. Which commands can I use to get the mac addresses of the devices plugged in?
Re: Devices on switch
The command is show mac-address-table
Reference: http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/command/reference/show2.html#wp2004764
Best regards.
Massimiliano.
Hall of Fame Super Gold
"sh mac-address-table" is the command, however, this will give you a very, very long list.
If you know a specific port, you can use the subcommand "sh mac-address-table interface ". Alternatively if you have the mac address and you want to know what port, you use the command "sh mac-address-table address ".
Hope this helps.
232
