DHCP broken on 3750 switch
Is anyone aware of a bug with DHCP on 3750-48PS running c3750-ipbase-mz.122-25.SEB4.bin?
Looking at the "sh proc cpu" output, there appears to be processes missing!
ip dhcp limited-broadcast-address
no ip dhcp conflict logging
ip dhcp pool data
network 10.5.249.0 255.255.255.0
default-router 10.5.249.1
domain-name lbe.gov.uk
dns-server 10.0.13.129 10.0.14.25
netbios-name-server 172.16.64.201 172.16.71.239
option 78 hex 010a.000d.7d
option 79 hex 014c.4245.2d53.434f.5045
lease 10
interface FastEthernet1/0/43
switchport access vlan 2
duplex full
speed 100
spanning-tree portfast
interface Vlan2
ip address 10.5.249.1 255.255.255.0
Switch#sh int f1/0/43 sw
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Access Mode VLAN: 2 (VLAN0002)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switch#
Switch#sh proc cpu | inc DHCP
123 0 4 0 0.00% 0.00% 0.00% 0 HULC DHCP Snoopi
137 0 25 0 0.00% 0.00% 0.00% 0 DHCPD Receive
141 0 29 0 0.00% 0.00% 0.00% 0 DHCP Snooping
180 0 2 0 0.00% 0.00% 0.00% 0 DHCP Security He
Switch#
Switch#sh debug
UDP:
UDP packet debugging is on
DHCP server packet debugging is on.
DHCP server event debugging is on.
DHCP server linkage debugging is on.
Switch#
*Mar 1 00:54:54.014: UDP: rcvd src=0.0.0.0(68), dst=255.255.255.255(67), length=308
Switch#
Silver
Re: DHCP broken on 3750 switch
Hi ,
can you paste show pro cup output.It is possible to reboot the switch once and check the status of output sh pro cpu | in DHCP.
satish
This problem IS a bug...CSCed91798
I cannot read bug reports as I am only a Cisco customer. Cisco only allow their sales companies access top Bug Tracker, presumably Cisco don't want customers to know about bugs so we can waste days on problems.
222
