Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
dhcp conflicts on my router
I am having an issue at one of my sites with DHCP. It seems that random machines will fall off the map and their phones as well until they are rebooted and get a new address.
Has anyone seen this before?
May 14 14:15:58.330 PDT: DHCPD: Seeing if there is an internally specified pool class:
May 14 14:15:58.330 PDT:   DHCPD: htype 1 chaddr 001e.3748.fd5e
May 14 14:15:58.330 PDT:   DHCPD: remote id 020a00000a4223fe2000000a
May 14 14:15:58.330 PDT:   DHCPD: circuit id 00000000
May 14 14:16:00.670 PDT: DHCPD: Seeing if there is an internally specified pool class:
May 14 14:16:00.670 PDT:   DHCPD: htype 1 chaddr 0009.6ba7.aea7
May 14 14:16:00.670 PDT:   DHCPD: remote id 020a00000a4223fe2000000a
May 14 14:16:00.670 PDT:   DHCPD: circuit id 00000000
May 14 14:16:07.671 PDT: DHCPD: Seeing if there is an internally specified pool class:
May 14 14:16:07.671 PDT:   DHCPD: htype 1 chaddr 0009.6ba7.aea7
May 14 14:16:07.671 PDT:   DHCPD: remote id 020a00000a4223fe2000000a
May 14 14:16:07.671 PDT:   DHCPD: circuit id 00000000
ip dhcp excluded-address 10.xx.35.250 10.xx.35.254
ip dhcp excluded-address 10.xx.35.120 10.xx.35.126
ip dhcp ping packets 0
ip dhcp pool Voice
   network 10.xx.35.0 255.255.255.128
   option 150 ip 10.xx.1.10 10.xx.1.15
   default-router 10.xx.35.126
   dns-server 10.xx.4.206 10.xx.4.208 139.142.2.3 66.244.223.130
ip dhcp pool Workstations
   network 10.xx.35.128 255.255.255.128
   default-router 10.xx.35.254
   domain-name chgfe.biz
rt-3825-1#sh ip dhcp conflict
IP address        Detection method   Detection time          VRF
10.xxxx.3        Gratuitous ARP     May 14 2010 12:15 AM
10.xx.35.51       Gratuitous ARP     May 14 2010 12:16 AM
10.xx.35.131      Gratuitous ARP     May 14 2010 08:45 AM
10.xx.35.132      Gratuitous ARP     May 14 2010 08:47 AM
10.xx.35.134      Gratuitous ARP     May 14 2010 09:12 AM
10.xx.35.137      Gratuitous ARP     May 14 2010 10:25 AM
10.xx.35.138      Gratuitous ARP     May 14 2010 12:07 PM
10.xx.35.139      Gratuitous ARP     May 14 2010 12:07 PM
10.xx.35.140      Gratuitous ARP     May 14 2010 12:07 PM
10.xx.35.141      Gratuitous ARP     May 14 2010 12:07 PM
10.xx.35.144      Gratuitous ARP     May 14 2010 12:08 PM
10.x.35.146      Gratuitous ARP     May 14 2010 02:03 PM
1 REPLY
Re: dhcp conflicts on my router
If you do:
clear ip dhcp conflict
does it solve the problem?
I think the issue is with the gratuitous arp. Look what I have found:
A Cisco router will send out a gratuitous ARP  message out of all interfaces when a client connects and negotiates an  address over a PPP connection. However, by default, gratuitous ARP  messages are not sent out when the client receives the address from the  local address pool. The ip  gratuitous-arps non-local command option is the default form and is  not saved in the running configuration.
http://www.cisco.com/en/US/docs/ios/12_3/ipaddr/command/reference/ip1_s1g.html#wp1080936
Let me know if this helps you somehow!
2227
