DHCP IP assignment avaya phone
john.wright
Level 3
Level 3
We have this config set up on our switches
ip dhcp pool VOIP
   network 10.51.203.0 255.255.255.0
   default-router 10.51.203.254
   option 242 ascii "MCIPADD=10.51.203.250,MCPORT=1719,HTTPSRVR=10.51.3.6"
   lease 10
interface GigabitEthernet0/3
switchport mode access
no logging event link-status
no snmp trap link-status
spanning-tree portfast
interface GigabitEthernet0/40
description phone station 8613 mac 001b.4f31.cae1
switchport access vlan 40
speed 100
duplex full
So the data vlan is default 1 on a seperate port.
And the avaya phone is on another port set to vlan 40.
I would like to use one port for both worksta and phone but how do I tell phone where its dhcp scope is and where dhcp is for the workstation?
if I need helper address where do I set it?
This is a L3 switch
interface Vlan1
ip address 10.51.3.237 255.255.255.0
ip helper-address 10.51.203.254
no ip route-cache cef
no ip route-cache
interface Vlan40
ip address 10.51.203.254 255.255.255.0
ip default-gateway 10.51.3.254
ip classless
ip route 0.0.0.0 0.0.0.0 10.51.3.254
ip http server
Gabriel Hill
Hello John,
You would have to configure a voice vlan on the switchport.
switchport voice vlan 40
The data vlan on the DHCP server has option 176 (for 46XX phones) and option 242 (96XX) phone. Since the avaya phone cannot learn about the "voice vlan" via CDP, DHCP must tell it where to go.
The 176/242 scope is setup as follows (ON THE DATA VLAN): L2Q=1,L2QVLAN=XXX (XX being the voice vlan)
Which will punt the request over to the voice vlan scope, where you have your 242 scope telling the phone where to contact the call server.
16 Replies 16
Gabriel Hill
Hello John,
Gabriel
So I need to add the voice vlan 40 to the port config. I got that.
But not sure where or how to add this.
L2Q=1,L2QVLAN=XXX (XX being the voice vlan)?
As you see the current setting  of op 242 is this:
Najaf has a good example. The way I've set this up in the past I only use "L2Q=1,L2QVLAN=40" (40 being your voice vlan) on the 242 DHCP option on the data dhcp scope.
Example:
ip dhcp pool DATA
  option 242 ascii "L2Q=1,L2QVLAN=40"
NOTE: I didn't type out all your data scope, just showing you what you would need added to it.
Of course you can use the full scope option, I just never found it necessary.
Add the 242 option to your DATA DHCP scope.
kcnajaf
Level 7
Level 7
Hi John,
Modify your conffiguration as below.
First you need to define data vlan. There use option 176 to define voice vlan using option 179 and 242
ip dhcp pool DATA
   network 10.51.3.0 255.255.255.0
   default-router 10.51.3.257
   option 179 ascii "MCIPADD=10.51.203.250,MCPORT=1719,HTTPSRVR=10.51.3.6,L2Q=1,L2QVLAN=40
  option 242 ascii "MCIPADD=10.51.203.250,MCPORT=1719,HTTPSRVR=10.51.3.6,L2Q=1,L2QVLAN=40"
   lease 10
ip dhcp pool VOIP
  option 179 ascii "MCIPADD=10.51.203.250,MCPORT=1719,HTTPSRVR=10.51.3.6"
   lease 10
Configure the switch port as below to define data and voice vlan
switchport access vlan 1
speed 100
duplex full
Also exclude the address which you are using for gateway
ip dhcp excluded-address 10.51.203.254
ip dhcp excluded-address 10.51.3.257
You dont need the dhcp helper in your case  since the dhcp client connected to the same switch. In normal case the DHCP helper would be on the L3 interface
Hope this helps.
Najaf
Please rate when applicable or helpful !!!
KC
I am unclear about why there are two dhcp scopes in your answer.
This location gets its IP for data from a server.
but the phones get their ip from the switch.
Would this work?
ip dhcp pool VOIP
   option 242 ascii L2Q=1,L2QVLAN=40,MCIPADD=10.51.203.250,MCPORT=1719,HTTPSRVR=10.51.3.6
    lease 10
kcnajaf
Level 7
Level 7
Hi John,
Forgot to mention that the phone initially pick up ip address from data vlan. Then with option 179/242 it will understand about the voice vlan and they pick up the correct ip from voice vlan
If you are not running data vlan on this switch you can configure the option 179/242 on where ever you are running the dhcp scope for data vlan even if it's on Microsoft dhcp sever.
Hope that helps
Najaf
KC
I forgot to mention the following in my initial problem description.
The current config of seperate ports for phone and data must remain.
But any additonal phone will be configed as phone and data on one port.
Will the existing phones have a problem if I make this change?
And just to be clear; you are saying put both of these IP pool scopes in the switch config and the data IP's will still be handed out by our dhcp server?
ip dhcp pool DATA
   option 179 ascii "MCIPADD=10.51.203.250,MCPORT=1719,HTTPSRVR=10.51.3.6,L2Q=1,L2QVLAN=40"
   lease 10
ip dhcp pool VOIP
   lease 10
kcnajaf
Level 7
Level 7
One phone on separate data and voice vlan and others Phone on same port of data and voice vlan will not have pbm.
But having 2 data vlan will be a problem. You will have choose one data vlan and configure option 179/242 on it.
Najaf
KC
I don't think I am making this clear.
The data vlan will not change. it is vlan 1 the default for all data.
here is what we have running as the config for ports on all the switches:
If the connected device is a workstation we have this set:
nterface GigabitEthernet0/6
If the connected device is a phone we have this:
interface GigabitEthernet0/31
speed 100
duplex full
The above port config will remain as you see it.
But
I want to add this port config in additon to what you see above so that we only have to use one port when a new person starts.
speed 100
duplex full
Will this work providing that we use the config you mentioned in previous response?
kcnajaf
Level 7
Level 7
Your port configuration looks fine.. That will work as expected..
My point was different. I was referring to where you place the data dhcp scope. You can have only one dhcp scope either on switch or on server. You cannot have one data scope on switch and other on server. Where ever you decide to run the dhcp scope there you need to mention the option 179/242 and tell what is the voice vlan. Otherwise phone is not going to know about voice vlan to pick the ip address from voice dhcp scope.
Hope your are clear now.
Najaf
KC
Thanks for all the reponses but I am still unclear.
The DHCP for DATA has always been on one of our servers and it is not changing.
The DHCP for PHONE has always been on the Cisco switch and it is not changing.
What do I need to add to my current VioP dhcp scope on the cisco switch so that the phones know how to get an IP?
This is what I have right now.
ip dhcp pool VOIP
lease 10
This is what you provided earlier.
ip dhcp pool VOIP
   lease 10
is this what I need to add to me cisco switch so that phones can get an IP?
kcnajaf
Level 7
Level 7
Use the configuration I have provided for dhcp voice pool.
On the data dhcp scope for vlan1 enable option 176/242 as per below URL
http://www.ipofficeassistance.com/HOWTO_DHCP_IP_Phones.html
And give a try with the connecting Avaya phone to one switch port and verify if it picks ip address
Najaf
KC
I just got my server support team to look at this.
He pointed out that the instructions indicate a change needs to be made to the IP phone scope on the server.
However, the phone scope is not on the server. It is on the switch.
Should that part of the instructions be ignored?
Thanks for your help
kcnajaf
Level 7
Level 7
We cannot ignore this. The data document clearly shows this need to be done on the data vlan... As far as you said saw far you are running the data vlan on the server and not on the switch.
For voice vlan we have already done this as per my recommended configuration.
Hope that helps
Najaf
