DHCP issue on router
Soho 97 router running 12.3.
Configured as a DHCP server however when DHCP client reaches end of lease router gives it a new IP address. Is there anyway to allow the client to retain the IP address when lease ends or bind the client to a particular IP address?
1 ACCEPTED SOLUTION
Re: DHCP issue on router
Configure the lease as infinite to retain the IP Address.
Router(config-dhcp)# lease {days [hours][minutes] | infinite}
To bind the client to a particular IP Address
use following commands
ip dhcp pool name
host address [mask | /prefix-length]
hardware-address hardware-address type
HTH...rate if helpful..
u can give the client a static IP from the PC
and exclude that IP from the DHCP pool in the router with command
ip dhcp exclude-address [ip address]
good luck
if helpful Rate
Sorry should have stated that I didn't want to give the client a static address.
Hall of Fame Super Silver
Gary
The normal behavior for DHCP is that when the lease reaches its end the client will receive the same address if it is available. Sometimes the DHCP server will have assigned that address to some other device (especially if the client has been off line for a while and if the address pool is small). From your description that seems to not be happening. Perhaps you can post the router configuration so that we can see it. Also it would help to know how many devices are receiving addresses from the router/server.
It is possible to statically bind an IP address to a specific MAC address. That might solve your issue. But if there are many devices that you want to do it for then it becomes a bit cumbersome.
Rick
ip dhcp pool name
nice one Satish this 4 point :)
156
