DHCP not working from Cisco router to HP switch
Can someone please help me with the config on my router and switch?
Here's the running config:
CISCO router:
hostname mykuldcmit-gw-1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp pool my-data
   network 10.60.3.0 255.255.255.0
   domain-name domainname.net
   default-router 10.60.3.254
   dns-server [dns ip]
   lease 0 8
   class my-data
      address range 10.60.3.16 10.60.3.223
ip dhcp class my-data
   relay agent information
      relay-information hex 0000000000000a3e03fe mask ffffffffffff00000000
login block-for 60 attempts 3 within 30
login delay 10
interface FastEthernet0/0
description ADSL WAN Interface
ip address 175.100.200.100 255.255.255.248
duplex auto
speed auto
interface FastEthernet0/1
description internal
ip address 10.60.1.2 255.255.255.0
duplex auto
speed auto
interface Serial0/3/0
no ip address
shutdown
no fair-queue
clock rate 2000000
ip route 0.0.0.0 0.0.0.0 175.100.200.100
ip route 10.60.0.0 255.255.224.0 10.60.1.254
no ip http server
control-plane
login
scheduler allocate 20000 1000
end
SWITCH Config:
Running configuration:
; J8692A Configuration Editor; Created on release #K.12.16
hostname "sw-1"
ip routing
snmp-server community "MLCBB" Operator
vlan 1
   name "management"
   untagged 24
   ip address 10.60.1.254 255.255.255.0
   no untagged 1,16-17
   exit
vlan 100
   name "voice"
   untagged 16-17
   ip address 10.60.20.254 255.255.255.0
   tagged 20
   voice
   exit
vlan 30
   name "data"
   untagged 1-15, 18-23
   ip helper-address 10.60.1.2
   ip address 10.60.3.254 255.255.255.0
   exit
vlan 999
   name "shared"
   untagged 1
   ip address 10.60.0.254 255.255.255.0
   tagged 21-22
   exit
dhcp-relay option 82 append ip
ip route 0.0.0.0 0.0.0.0 10.60.1.2
ip route 10.0.0.0 255.0.0.0 10.60.1.2
13 Replies 13
devils_advocate
Level 7
Level 7
Presumably none of the hosts in Vlan 30 are getting DHCP addresses?
Is your HP switch doing InterVlan routing?
I think the second IP route statement on the HP may be causing you an issue as its effectively saying, 'To reach any host starting with 10., forward the packet to 10.60.1.2'. You don't want that to happen as your HP switch has the connected interfaces in the majority of the 10.* network.
I did try to remove the second ip route on the switch but still not working.
cadet alain
Can you also enter this command on the Cisco device:
ip dhcp relay information trusted
Alain
I tried adding the command "ip dhcp relay information trust-all" but still not working.
Here's the new config:
SWITCH Config:
hostname "ProCurve Switch 2610-24-PWR"
console inactivity-timer 5
ip routing
snmp-server community "public" Unrestricted
vlan 1
   name "DEFAULT_VLAN"
   untagged 25,27-28
   ip address 10.160.1.254 255.255.255.0
   no untagged 1-24,26
   exit
vlan 30
   name "Data"
   untagged 1-15,18-20,24
   ip address 10.160.3.254 255.255.255.0
   ip helper-address 10.160.1.1
   exit
vlan 999
   name "Shared"
   exit
vlan 100
   name "Voice"
   untagged 16-17,21-22
   ip address 10.160.10.254 255.255.255.0
   tagged 20
   exit
vlan 31
   name "LAN via SSG5"
   untagged 23,26
   exit
ip route 0.0.0.0 0.0.0.0 10.160.1.1
password manager
ROUTER Config:
Current configuration : 2570 bytes
version 12.4
no service timestamps debug uptime
no service timestamps log uptime
hostname my-gw-1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
   network 10.160.3.0 255.255.255.0
   domain-name docomointertouch.net
   default-router 10.160.3.254
   lease 0 8
   class my-data
      address range 10.160.3.16 10.160.3.223
ip domain name domainname.net
login delay 10
no vlan accounting input
ip access-group firewall in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
ip address 10.160.1.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
duplex auto
speed auto
no ip address
shutdown
no fair-queue
clock rate 2000000
ip route 0.0.0.0 0.0.0.0 175.100.200.99
ip route 10.160.0.0 255.255.224.0 10.160.1.254
no ip http server
ip nat translation tcp-timeout 42300
ip nat translation udp-timeout 150
ip nat translation finrst-timeout 45
ip nat translation syn-timeout 45
ip nat translation dns-timeout 45
ip nat translation icmp-timeout 45
ip nat translation max-entries 4000
ip nat pool nat 175.100.200.100 175.100.200.100 netmask 255.255.255.224
ip nat inside source route-map nat pool nat overload
ip access-list extended firewall
permit ip any host 175.100.200.100
permit icmp any any
ip access-list extended nat
permit ip 10.160.0.0 0.0.31.255 any
permit ip host 0.0.0.0 host 255.255.255.255
route-map nat permit 10
match ip address nat
control-plane
line con 0
login
line aux 0
line vty 0 4
login
end
When I do "debug ip dhcp server packet/events", this is what I only got:
*Nov 22 15:38:09.279: DHCPD: checking for expire.
Please advise what I am missing on my config.
Thank you.
I am not sure if the DHCP service is enabled in the router.
conf ter
service dhcp
Please check the same.
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
Hi Karthick,
"service dhcp" is already enabled.
Still no luck.
access-list 199 permit udp any eq bootpc any eq bootps
access-list 199 permit udp any eq bootps any eq bootpc
do debug ip pack detail 199
Try to get a DHCP address from one of the hosts connected to the switch and post log output from router
Alain
Hi Alain,
I did this and here's the output.
my-gw-1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
my-1(config)#access
my-1(config)#$ 199 permit udp any eq bootpc any eq bootps
my-1(config)#$ 199 permit udp any eq bootps any eq bootpc
my-gw-1(config)#^Z
my-gw-1#
my-gw-1#debug ip pack detail 199
IP packet debugging is on (detailed) for access list 199
my-gw-1#term mon
my-gw-1#
*Nov 23 00:44:09.296: DHCPD: checking for expired leases.
*Nov 23 00:46:09.296: DHCPD: checking for expired leases.
I disable/re-enable the interface from the switch where the pc is connected. It's the one trying to get the dhcp ip address.
Still not working.
it seems like you're not receiving any dhcp packet from the host , to rule out the logging on the router can you do this:
undebug all
conf t
access-list 198 permit icmp any any
do debug ip pack 198
and ping the router from the switch to see if you got logging output.
if you don't then verify logging with sh log and post output here.
if you got output for the ping then we'll have to take a look at the switches.
Alain
Hi Alain,
Thank you for your reply.
Here's the output when I ping the router from the switch.
*Nov 23 16:35:22.708: IP: tableid=0, s=10.160.1.254 (FastEthernet0/1), d=10.160.1.1 (FastEthernet0/1), routed via RIB
*Nov 23 16:35:22.708: IP: s=10.160.1.254 (FastEthernet0/1), d=10.160.1.1 (FastEthernet0/1), len 50, rcvd 3
*Nov 23 16:35:22.708: IP: tableid=0, s=10.160.1.1 (local), d=10.160.1.254 (FastEthernet0/1), routed via FIB
*Nov 23 16:35:22.708: IP: s=10.160.1.1 (local), d=10.160.1.254 (FastEthernet0/1), len 50, sending
I have posted the switch config on top. Please advise.
Jenalyn
Can you assign a static IP to a host in vlan 30 and ping the router 10.160.1.1 and tell us if you are successful.
What port on the switch is connected to router and to host in vlan 30 ?
Also on router you can edit your nat  ACL:
no 20
and modify your static route:
no ip route 10.160.0.0 255.255.224.0 10.160.1.254
ip route 10.160.3.0 255.255.255.0 10.160.1.254
ip route 10.160.10.0 255.255.255.0 10.160.1.254
if the static host can communicate with the router and still a host configured with ipconfig/release and ipconfig/renew can't get an IP then we can try to capture packets on the vlan 1 on the switch.
Alain
