11-08-2006 04:14 AM - edited 03-05-2019 12:41 PM
hi all
how can i activate a dhcp server on a catalyst 2950?
best regards
11-08-2006 04:20 AM
Hi Amine
I dont think its possible to enable DHCP server feature in Cisco 2950 Switch.
regds
11-08-2006 04:22 AM
i think you could not enable dhcp server on a switch unless it has layer 3 functionality or you could do this from global config mode do --> ip dhcp ? if you get a bunch of options then you could do dhcp server if you get an error tough luck
11-08-2006 04:40 AM
Hi Amine,
Yes 2950 can be configured as DHCP server however there are some limitations.
Check this discussion chain and you will be good to go
Ankur
11-08-2006 05:31 AM
YES DHCP server is possible, juz find how on a 2950
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp pool TEST
network 10.1.1.0 255.255.255.0
domain-name test.org
default-router 10.1.1.254
dns-server 10.1.1.2
ip dhcp-server 10.1.1.254
interface vlan 2
ip address 10.1.1.254 255.255.255.0
hope you understood,
rate this post if satisfied.
