Webcast-Catalyst9k
DHCP Pool:
I have two core switches and my customer required the core switch to provide dhcp. Should I configure the dhcp pool on both switches to provide redundancy.
Can someone post an example of this configuration for dhcp pool on both core
switches.
Thanxs.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: DHCP Pool:
Colm
If the DHCP pool is for a vlan that is directly connected then no you don't. Only if the switch is a DHCP server for clients that are more than 1 hop away would you need an ip helper-address.
"If the pool on the first core is used up, will the clients get there ip address from the second core switch?"
Should do because each switch will see a DHCP request from the client, providing your core switches are connected via a L2 link that includes that vlan.
Jon
Re: DHCP Pool:
Colm
You can't configure the same pool on both switches because the switches don't communicate so they could hand out the same addresses. What you can do is configure half the pool on one switch and the other half on the the other switch.
If you choose a big enough pool then half the pool should be enough for all your clients. ON each switch you would need to exclude the IP's used on the other switch eg.
DHCP pool 192.168.5.0/24
on switch 1
ip dhcp excluded-address 192.168.5.129 192.168.5.254
ip dhcp pool SW1
network 192.168.5.0 /24
default-router 192.168.5.1
on switch 1
ip dhcp excluded-address 192.168.5.1 192.168.5.128
ip dhcp pool SW1
default-router 192.168.5.129
See this link for all options in DHCP setup -
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iad_dhcp_svr_cfg_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1046221
Jon
Re: DHCP Pool:
Thanks Jon.
Do I need to add an ip helper-addresss under the SVI on each core switch?
Re: DHCP Pool:
Colm
Jon
571
