11-20-2006 11:08 AM - edited 03-05-2019 12:56 PM
Hello all,
I have implemented a CISCO 2811 ISR in our network. I configured a DHCP on the router but it is not working. None of the clients are able to get a DHCP address from this 2811. Here is how I have configured the DHCP.
ip dhcp smart-relay
ip dhcp use vrf connected
ip dhcp use vrf remote
ip dhcp binding cleanup interval 600
ip dhcp excluded-address 10.0.0.1 10.0.0.239
ip dhcp pool INTERNAL
import all
network 10.0.0.0 255.255.255.0
dns-server aa.bb.cc.dd x.y.z.s
default-router 10.0.0.1
lease infinite
Am I doing something wrong?
Please suggest.
11-20-2006 02:02 PM
Hi ,
configure the following command on the router.
service dhcp
ip bootp server
check the below link -Configuring DHCP
satish
11-29-2006 09:59 PM
Well i do not doubt DHCP server does not work normally. To release IP address from DHCP server, server should compare giadd with clinet subnet network.
IS this interface connected into 10.0.0.0/24 sunbnet ?
To verify DHCP packet works properly, command
"debug ip dhcp server packet".
If you see dhcp discovery packet from clinet, it's okay. Then must see dhcp offer packet.
