Webcast-Catalyst9k
DHCP- query
please suggest on the below mentioned scenario ,
currently The network connectivity as fallows
                                              1) connectivity   ROUTER--- > L3 switch -- host machine
                                              2) On  L3 switch  DHCP pool configured , all desktop connected to same switch
                                              2) Router and L3 connected  via OSPF dynamic routing protocol
                                              3) Gate way for the  desktop is switch  VLAN  10 configured with IP 10.10.x.1 /24
changes  :
             1) Need  to move  desktop gateway ( 10.10.x.1) on the router LAN interface insted of Switch vlan 10.
             2) the connectivity between router and Switch will be L2  ,
             3) DHCP pool will be on the switch  only  , not on the router
             4)  default route  will be configured on the switch towards router LAN interface  ( 10.10.x.1/24)
In this scenario is DHCP works ( configuration  mentioned below ) ??  .
On  DHCP  configuration  "default-router 10.10.x.1 "    for the DHCP scope .    10.10.x.1/24 currently on the switch
the  desktop gateway address 10.10.x.1 will be moved to router LAN interface  .
Is  host machine  will  install  gate way address ( through DHCP pool  ) and able reach the gateway  10.10.x.1  ( router)
I think it should work since  till router LAN interface  its broadcast domain .   please suggest  .
Existing Switch configuration :
ip dhcp pool test
   network 10.10.x.0 255.255.255.0
   domain-name test.com
   dns-server  1.1.1.1
   lease 5
ip dhcp excluded-address 10.10.x.1 10.10.x.50
Interface vlan 10
ip address 10.10.x.1 255.255.255.0
196
