02-14-2012 12:00 PM - edited 03-07-2019 04:56 AM
I am trying to configure two 3845 routers to act as dhcp server and dhcp relay. Clients are connected to the router that relays all dhcp requests to the vrf instance which is used to connect it to the router wich is running dhcp server.
Router1
ip vrf dhcp_dns
rd 8:1
int gi0/0
ip vrf forwarding dhcp_dns
ip address 192.168.200.5 255.255.255.248
int gi0/1.5
encapsulation dot1Q 5
ip dhcp relay information trusted
ip vrf forwarding Client_A
ip address 192.168.201.1 255.255.255.0
ip helper-address vrf dhcp_dns 192.168.200.6
ip route vrf dhcp_dns 0.0.0.0 0.0.0.0 192.168.200.6
Router2
dhcp pool Client_A
network 192.168.201.0 255.255.255.0
default-gateway 192.168.201.1
interface GigabitEthernet0/0
ip address 192.168.200.6 255.255.255.248 interface GigabitEthernet0/0
ip route 0.0.0.0 0.0.0.0 192.168.200.5
So far I can see dhcp requests comming from the R1 and dhcp server on R2 replies with the dhcp offer but PC is not getting any ip.
Thank you,
02-14-2012 06:34 PM
Maybe the typo on first lines.
ip vrf dhc_dns
rd 8:1
int gi0/0
Hope this helps
Eugen
02-15-2012 05:53 AM
Thank you for the reply,
It's a typo in the message... I didn't copy and paste the router config but vrf definition is correct in the router config.
02-15-2012 06:58 AM
what do you see if you enable dhcp debugs on Router 1?
Riccardo
02-15-2012 07:20 AM
This is what I have on the routers. 7206VXR is the dhcp server and 3845 is
the dhcp relay.
It looks like 3845 is forwarding bootrequests and 7206 is replying but PC
still doesn't get ip address...
Val Kotliarov ? Certified IT Specialist
IBM Canada Ltd,
IBM Business Continuity and Resiliency Services
3500 Steeles Avenue East, Markham, Ontario, L3R-2Z1
External Number: (905) 316-7312 Tie Line: 886-7312
Cell Number: 416-819-2151
Fax Number: 905-305-9850
Pager Number: 416-2324938
E-MAIL: KOTLIAR@CA.IBM.COM
To: Valeri Kotliarov/Markham/IBM@IBMCA
Date: 15/02/2012 10:02 AM
Subject: - Re: dhcp relay for vrf
Home
created by Riccardo Simoni in LAN, Switching and Routing - View the full
discussion
Riccardo
Reply to this message by going to Home
Start a new discussion in LAN, Switching and Routing at Home
02-15-2012 07:24 AM
can you paste the debug outputs?
would like to make sure the dhcp packet is sent out to the correct interface
02-15-2012 07:40 AM
Done,
I included screen shots for dhcp server and dhcp relay as well.
IBM Canada Ltd,
Date: 15/02/2012 10:28 AM
Home
discussion
interface
02-15-2012 07:27 AM
Hi Riccardo,
Here it is.
This is what I have on the routers. 7206VXR is the dhcp server and 3845 is the dhcp relay.
It looks like 3845 is forwarding bootrequests and 7206 is replying but PC still doesn't get ip address...
02-15-2012 08:02 AM
the debug of the 3845 does not show whether it sends the dhcp offer back to the PC. But since it is not the DHCP server it could be simply due to the type of debugs which you enabled.
Try to have a look to the following guide which contains 'enanched' ways to troubleshoot similar issue. Specifically pay attention to the section called "Verify Router is Receiving DHCP Request and Forwarding Requests to DHCP Server Using debug Commands" which includes smart ways to configure debugs ACLs.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a00800f0804.shtml
The goal is to verify if the issue is on
1. 3845 not receiving dhcp offer from 7206
2. 3845 not forwarding it to the PC (or forwarding it to the wrong interface)
3. PC not receiving it for some reason
