ā12-04-2013 05:32 AM - edited ā03-07-2019 04:55 PM
Is it possible to establish an "DHCP-Relay"-function in an "WS-C2960-24PC-L" or do I need a router (L3).?
Solved! Go to Solution.
ā12-05-2013 02:37 AM
HI Kvessgard.
Can u plz mark this question as answered, it may help others.
Dont forget to rate helpful posts.
ā12-04-2013 06:09 AM
Hi Kvessgard,
I think this is supported on 2960 with LAN base Image:
Here is the link:
for more information, please visit: https://supportforums.cisco.com/thread/2124839
ā12-04-2013 06:23 AM
Yes I have read this information but I canĀ“t figure out how to use it?
Do you have an sample for this?
I do have an Vip-Device on a port on such a switch
and the DHCP-server is on another LAN.
ā12-04-2013 06:28 AM
The vlan that the device is in should have a L3 vlan interface ? So, for example, if the vlan was vlan 10 in your config you should see something like -
int vlan 10
ip address
if you do then under that vlan interface configure an ip helper-address ie.
int vlan 10
ip address
ip helper-address x.x.x.x <--- where x.x.x.x is the IP address of the DHCP server.
Jon
ā12-04-2013 06:31 AM
Hi ,
U must have a vlan on switch.
Just assign:
Interface vlan x
ip helper-address
make sure your VIP device conected to right port on switch.
ā12-04-2013 06:38 AM
Please don't forget to turn on "service dhcp", else the helper isn't enaged; sorry if granny and eggs though!
Andy.
ā12-05-2013 02:35 AM
Thanks it is now solved.
HI Kvessgard.
