Dhcp server in VRF
Siemens_SWP
I have a DHCP server placed in a server VRF, i also have some clients in another VRF. I want the Dhcp to lease out ips to my clients in the other VRF. All traffic is going through a firewall, both bootps and bootpc has been allowed in the firewall, but it doens´t work. I have provided the configuration.
Any one has some clues how make this happen ?
5 Replies 5
SOcchiogrosso
Level 4
Level 4
You should be able create a new DHCP pool and asign the DHCP pool to the VRF
ip dhcp pool pool1
  vrf pool1
Basic IOS DHCP Config
http://ccie-or-null.net/2011/04/29/cisco-ios-dhcp-server-option-43/
Putting DHCP scope in a VRF
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_dhc3.html#wp1014987
CCNP, CCIP, CCDP, CCNA: Security/Wireless
Blog: http://ccie-or-null.net/
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
If I understand correctly he wants the DHCP server to hand out the IP addresses not create a DHCP pool on the switch.  You mentioned that you have opened up the firewall, however looks like the VLAN's are missing the "ip helper-address dhcp-ip"
Siemens_SWP
I want to use my windows 2008 r2 as the DHCP server.
@ Mohammad Ali - I have allready tried to put in the VRF like this- ip helper-address vrf 600 149.212.47.103   its not possible to just put in the vlan.
There is some good information here if you haven't seen this link already:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t8/feature/guide/ftdhmpls.html#wp1028663
jidemudia
You DHCP Server needs to support option 82. If the DHCP Server resides in a different VRF from your client systems, you have to enable the option 82 parameter on the Cisco Router and your DHCP server needs to support it as well. When the traffic comes back through the Server VRF. The Server VRF needs to know what the DHCP request came from to properly deliver the request.
