Webcast-Catalyst9k
DHCP Server not working on 1721?
I've setup a 1721 on an adsl connection. Everything works ok except the local dhcp server. Its setup as per all the proper cisco documentation but for some reason it just will not serve addresses to client pc's.
Ive ran a dhcp debug and tried an ipconfig /renew from a client, but the router just sits there and see's no events.
ANyone got any ideas?
Re: DHCP Server not working on 1721?
can you post the configs
Narayan
Did you enable " Service DHCP " in the global configuration mode. Please paste the router configuration.
-amit singh
hi Guys
Here is my config, passwords and WAN IP addresses have been removed to protect the innocent :D
version 12.3
service config
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
enable secret ********************
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.7.1
ip dhcp pool HOME
import all
network 192.168.7.0 255.255.255.0
default-router 192.168.7.1
dns-server **************** ****************
lease infinite
no ip ips deny-action ips-interface
ip name-server 212.87.64.7
ip name-server 212.87.64.10
no ftp-server write-enable
interface ATM0
description ADSL line interface
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
description LAN
ip address 192.168.7.1 255.255.255.0
ip access-group 101 in
ip nat inside
ip virtual-reassembly
speed auto
no cdp enable
interface Dialer1
description Connection to ADSL
ip address *********** 255.255.255.252
ip access-group 102 in
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname ****************
ppp chap password ****************
ppp pap sent-username **************** password ****************
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 192.168.7.2 3389 80.175.102.137 3389 extendable
ip nat inside source static tcp 192.168.7.2 29310 80.175.102.137 29310 extendable
ip nat inside source static udp 192.168.7.2 29310 80.175.102.137 29310 extendable
access-list 100 deny ip any any
access-list 101 permit ip 192.168.7.0 0.0.0.255 any
control-plane
line con 0
exec-timeout 0 0
login
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
end
Hall of Fame Super Gold
Josh
I believe that the problem is the access list which is applied inbound on the FastEthernet interface:
The problem is that the DHCP request from the client has source address of 0.0.0.0 and this is not permitted by your access list. If you add a permit for host 0.0.0.0 I think that you will see DHCP work.
Rick
Add either of the following to your access-list
as suggested by Rick
access-list 101 permit ip host 0.0.0.0 host 255.255.255.255
A better option would be to use the below
access-list 101 permit udp any any eq 67
access-list 101 permit udp any any eq 68
Try this and let us know how it goes
HTH, rate if it does
Narayan
Hi Guys
The first options works, thanks!
Ive not tried the second option, but will consider that if i fix the other issue ive been having...
Which is that the router seems to drop the adsl connection regylarly, almost hourly. Ive rebuild a new config using SDM and also upgraded to the latest IOS, but nothing seems to fix the issue.
I know my line is ok as my old cheapy router stays connected forever pretty much.
Is there a chance the WIC is faulty?
882
