DHCP server on Catalyst 2960X?
Mike Assel
Level 4
Level 4
Can anyone confirm for me whether or not the Catalyst 2960X can function as a DHCP server?  I did use the feature navigator and the answer seems to be no, but I wanted to get confirmation because I'm not sure I was using the tool correctly.  Thanks,  Mike
5 Replies 5
Hello
apparently is can
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/security/configuration_guide/b_sec_152ex_2960-x_cg/b_sec_152ex_2960-x_cg_chapter_01101.html
Res
paul
Kind Regards
Paul
OK, so how do I confirm which software version supports this?
"Your software release may not support all the features documented in this module."
I'd really like to know how I could confirm this info on my own using the feature navigator.
Thanks,  Mike
Hello
what iOS are you currently using - that URL referenced 15.0 train
you could also try enabling it to test if it supported
config t
service dhcp
ip dhcp pool Test
If you find cisco navigator hard to use then maybe you could try using the support guides and check out the command references for your switch
http://www.cisco.com/c/en/us/support/switches/catalyst-2960-series-switches/products-command-reference-list.html
Kind Regards
Paul
Can anyone confirm for me whether or not the Catalyst 2960X can function as a DHCP v6 server?
Syamsul
According to the Cisco Feature Navigator the 2960X does not support this.  You could test for sure by trying to configure the feature.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipv6/configuration/15-2mt/ipv6-15-2mt-book/ip6-dhcp.html#GUID-D7BDF558-0F3D-473F-AF16-AC7AD8172778
