11-28-2006 01:57 PM - edited 03-05-2019 01:04 PM
I having some difficulties configuring DHCP snooping. My network consist of 2950C-24's connected to 3550-24-FX's via fiber and the 3550-24-FX's connected to a 3750-48TS via fiber GBIC card. My DHCP server is located on the 3750 and all my workstations are on the 2950's. I can get DHCP snooping to work correctly when I directly connect the 2950 to the 3750 via trunk ethernet connection but when i try to use the 3550 is when I run into troubles. any help with this would be greatly appreciated.
11-28-2006 04:13 PM
Laurent,
I hope this URL can help
11-30-2006 06:44 AM
I took at the document and it seems I have it set up right. I have will paste in a brief config of what i have right now:
*******3750
ip dhcp snooping
ip dhcp snooping vlan 4,240,252
no ip dhcp snooping information option
! Connection to 3550
interface GigabitEthernet1/0/2
switchport mode dynamic desirable
! Connection to DHCP SERVER
interface FastEthernet1/0/37
switchport access vlan 240
switchport mode access
duplex full
speed 100
no cdp enable
spanning-tree portfast
ip dhcp snoop trust
********3550
ip dhcp snooping
ip dhcp snooping vlan 240
ip dhcp snooping vlan 252
! Connection to 2950
interface FastEthernet0/1
duplex full
ip dhcp snooping trust
! Connection to 3750
interface GigabitEthernet0/1
switchport mode dynamic auto
********2950
ip dhcp snooping
interface FastEthernet0/25
switchport mode trunk
udld port
11-30-2006 07:23 AM
This is probably due to wrong trust states configured on the 3550. Should be:
PC -> untrusted 2950 trusted -> untrusted 3550 trusted -> untrusted 3750 trusted -> DHCP server.
The switch does not build DHCP snooping table on the trusted port. This is not what you want, right?
12-05-2006 06:08 AM
Sorry I was out of the office for a few days!!
I need a binding table on the 2950 and 3750. The only things connected in my network on the 3550's are the 2950's.
So I tried the config you suggested and still can not get my reservation from the DHCP server. What other commands do I need to include to make this work??
Thanks!!
12-05-2006 12:59 PM
Please make sure you have "ip helper-address" commands under inerfaces vlan240 & vlan252 within cat3750 to point to your DHCP server. Also please make sure your trunks are set up correctly (e.g. to autonegotiate trunking, the the interfaces must be in the same VTP domain) - I would suggest to put interfaces in trunk mode to trunk unconditionally at least for the testing purposes. As you are not using option 82 (interface tracker) your configuration should work both as configured originally and as suggested by one of the posts above.
Best regards,
Antonin
