DHCP snooping vs routed port
Hi to All,
I have multiple VLANs configured on a L2/L3 switch (cisco 3750) and one DHCP server configured on wan [using ip helper-address on the switch I forward the DHCP request on a L3 interface (the port vs the DHCP server is a routed port)].
If I enable dhcp snooping on the switch I need also to configure the TRUSTED PORT (the port vs the DHCP server) but I cannot configure it as it's a L3 routed port vs the wan router.
How it's possible to enable DHCP snooping on the switch and use the DHCP server on the "wan" ?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: DHCP snooping vs routed port
Hello Roberto,
I was thinking of:
ip dhcp snooping
! enables for all vlans
no ip dhcp snooping vlan 3
! disabling DHCP snooping for core facing
! vlan
but your configuration should be fine, only doubt is that a general
ip dhcp snooping
may be needed
Hope to help
Giuseppe
Hello Roberto,
a routed port is not part of any Vlan so DHCP snooping is not running on it.
if you use an SVI + a physical port as your core facing link you can still disable ip igmp snooping on the associated L2 vlan.
Hope to help
Giuseppe
Hi Giuseppe,
thanks for the info.
Please can you check the conf. and tell me if will be correct ?:
THE CURRENT SWITCH CONFIGURATION
interface GigabitEthernet1/0/1
description ** DHCP pc 192.168.2.0/24 **
switchport access vlan 2
switchport mode access
load-interval 30
interface GigabitEthernet1/0/2
load-interval 30
interface GigabitEthernet1/0/3
load-interval 30
interface GigabitEthernet1/0/24
description ** TO WAN ROUTER **
no switchport
ip address 192.168.254.254 255.255.255.252
interface Vlan2
description ** LAN **
ip address 192.168.2.254 255.255.255.0
ip helper-address 192.168.1.254
ip forward-protocol udp bootpc
ip route 192.168.1.0 255.255.255.0 192.168.254.253
THE NEW SWITCH CONFIGURATION
ip dhcp snooping Vlan 2
interface Vlan3
description ** LAN TO WAN ROUTER **
ip address 192.168.254.254 255.255.255.0
switchport
switchport access Vlan 3
ip dhcp snooping trust
Roberto Taccon
Hello Roberto,
I was thinking of:
ip dhcp snooping
! vlan
ip dhcp snooping
may be needed
Hope to help
Giuseppe
1087
