09-21-2007 01:10 AM - edited 03-05-2019 06:37 PM
Hi everybody,
We 've tried to configure dhcp-static on a router.
When we use type "id" with client identifier, it works.
But when we use type "1" with mac-address, pc can't get ip address.
Could someone help, please?
09-21-2007 01:21 AM
Can you show us your config?
Kevin Dorrell
Luxembourg
09-21-2007 01:40 AM
Hi Dorrell,
Here attached (dhcp-static.txt) the config with the content of address-mapping files.
There's also output debug.
09-21-2007 06:39 AM
09-27-2007 12:46 AM
Hi Dorrell,
Have you seen something wrong in the conf or in the map file?
config :
ip dhcp pool add
origin file tftp://192.168.102.38/add.txt
dns-server 62.56.162.33 62.56.240.40
default-router 41.204.12.9
ip dhcp pool add1
origin file tftp://192.168.102.38/add1.txt
default-router 41.204.15.3
interface Ethernet0/0
ip dhcp relay information trusted
ip address 41.204.15.3 255.255.255.240
ip address 41.204.12.9 255.255.255.224 secondary
map file :
!IP address Type Hardware address Lease expiration
41.204.12.2 id 0100.13CE.87FA.C5
41.204.12.3 1 0014.22be.35da Infinite
09-27-2007 02:34 AM
I think in your pools, you will have to put in network statements to bind them to the interfaces:
ip dhcp pool add
network 41.204.12.0 255.255.255.224
ip dhcp pool add1
network 41.204.15.0 255.255.255.240
Don't forget to write exclusion clauses for your router addresses.
Kevin Dorrell
Luxembourg
09-27-2007 05:02 AM
ip dhcp pools must contain the network statments as Kevin said.
Otherwise the pools with not know which interfaces to associate the request / assignments with.
09-27-2007 06:26 AM
I was just thinking about my statement ".. in order to bind the pool to an interface .." and wondering how that related to relayed DHCP. Maybe rather it binds it to a route. So if a DHCP request comes in on an interface, and you have a pool whose network statement matches a route that can be found via that interface (connected or remote), then you serve the request. Is that how it works? If so, it somehow reminds me of the RPF check in multicast.
Can someone throw some more light on it?
Kevin Dorrell
Luxembourg
09-27-2007 06:29 AM
Kevin,
From my understanding, that is how it is applied / works.
09-27-2007 11:26 PM
Hi all,
We need to attribute IP adress depending on mac adress. So, we need to specify a map between mac - ip but not use network command.
We have problem using the command "origin file" with mac-adress.
