Diameter for Rapid-PVST
vishwancc
Level 3
Level 3
Hi all,
Could any one tell is the diameter for stp and for rapid-pvst is same to calculate the forward delay and max-age time.
eg
a---->b---->c---->d
for STP diameter 4 and for rapid-pvst also 4
Chao
Vishwa
kishan1984
yes,default net diameter is 7 for stp and 802.1w.
Hi Kishan,
I am a bit confused here on why its has to be same for both since in rstp a switch send hello without waitinig to receive hello from the root. Or is it diameter does not depend on which stp are you running.
Chao
Vishwa
