05-15-2007 03:13 AM - edited 03-05-2019 04:04 PM
Greetings
Both ip flow ingress and route-cache flow commands are available on my Cat6513 IOS 12.2(18). When reading the the command reference it's unclear to me what the difference is.
Can someone please shed light on this for me?
Fredrik Hofgren
05-15-2007 03:39 AM
The "ip route-cache flow" can be used only under the main interface, while the "ip flow ingress" was an enhancement to be used under subinterfaces.
The NetFlow Subinterface Support feature provides the ability to enable NetFlow on a per-subinterface basis. In a scenario in which your network contains thousands of subinterfaces and you want to collect export records from only a few subinterfaces, you can fine-tune your collection of data to only specified subinterfaces. The result is lower bandwidth requirements for NetFlow Data Export (NDE) and reduced platform requirements for NetFlow data-collection devices.
Using the NetFlow Subinterface Support feature, you can enable NetFlow on selected subinterfaces using the ip flow ingress command. If you configure the ip flow ingress command on a few selected subinterfaces and then configure the ip route-cache flow command on the main interface, enabling the main interface will overwrite the ip flow ingress command and data collection will start from the main interface as well as all the subinterfaces. In a scenario in which you configure the ip flow ingress command and then configure the ip route-cache flow command on the main interface, you can restore subinterface data collection by using the no ip route-cache flow command. This configuration will disable data collection from the main interface and restore data collection to the subinterfaces you originally configured with the ip flow ingress command.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080154dd2.html
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
05-15-2007 04:02 AM
Thank you for clarifying the issue for me. As I understand, since I don't use subinterfaces, the effect of these two commands are the same.
05-15-2007 08:41 AM
Thanks for your great explanation. Good to know.
hieu
05-16-2007 05:50 AM
Good explanation as always from Mohammed :-)
Narayan
05-16-2007 06:11 AM
Hi Narayan,
Thank you very much, i really appreciate to be appreciated from a person like your self :)
BR,
Mohammed Mahmoud.
08-12-2013 10:44 PM
Al-salam alikom Mohammed,
What about this command:
ip route-cache same-interface
What's its purpose?
08-13-2013 01:16 AM
Essam,
“ip route-cache” controls the use of switching methods for forwarding IP packets:
ip route-cache [same-interface | flow | distributed | cef | policy]
Inayath
08-15-2013 03:56 AM
Thanks Inayath,
I read this description before, but I couldn't understand what is it use for? when do we use it? and what are the benifits?
Best Regards,
08-15-2013 04:24 AM
Essam, Regarding your query, "ip route-cache same-interface" will enable fast switching on the interface. It is not recommended as it will put load on CPU but if your router has enough resources than you should be alright. You can verify what switching method is actually in use by issuing "sh ip interface ."
By enabling fast-switching through this command , we are only enabling fast-switching for same interface i.e. only for packets going out through same interface on which they were received. Normal cef switching will still be enabled.
Inayath
***Plz rate if this info is helpfull***********
08-15-2013 11:23 PM
Essam,
Did that clarified your doubt?
