Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Difference between SUP-6-E and SUP-6-E lite
Hi all,
I'm trying to configure a Catalyst 4507R with a Supervisor 6E but I noticed there is another Supervisor 6E lite. I can't find information about the "lite" version of this supervisor.I would like to know the difference of performances.
Could anyone help me?
Thank you.
Giuseppe.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Blue
Re: Difference between SUP-6-E and SUP-6-E lite
gpangallo wrote:
Hi all,
Thank you.
Giuseppe.
Giuseppe
Have a look at the attached doc which covers both the 6E and 6E lite.
Jon
Hi all,
Thank you.
Giuseppe.
Hi Giuseppe,
Check out the below link on sup 6E and sup 6E lite hope that helps
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps9294/product_data_sheet0900aecd806df543_ps4324_Products_Data_Sheet.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_announcements0900aecd806ed5d2.html
If helpful do rate the post
Ganesh.H
gpangallo wrote:
Hi all,
Thank you.
Giuseppe.
Giuseppe
Jon
Hi all,
Thank you.
Giuseppe.
Hi Giuseppe,
Ganesh.H
2160
