difference between switch stacking and ether channel bundling
dear all,
please explain the difference between switch stacking and ether channel bundling.
thank alot
raj
Re: difference between switch stacking and ether channel bundlin
Hi Raj,
I think that this document can help you understand the benefits of using stacking (mainly management benefits), and kindly be aware of which switch supports which stacking technology:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#stack_tech
HTH,
Mohammed Mahmoud.
Stacking means backplanes are supposed to be conected by an external link allowing the hardware to behave as if htere is only one swich. From that point of view, there is only one management entity, only one STP bridge id on the network, one CAM table, etc.
Ethernet bundling means the switches are conected to each other as standalone entities by standard interfaces (as many as you like, but stardar interfaces after all). That means there are two separate management entities, two STP bridge id, two CAM tables, etc.
The expected performance of etherchanneled switches is much lower that what could be achieved with stacking technologies. Of course, switched with etherchannels are much cheaper that their stacked counterparts.
386
