ā01-22-2014 09:21 PM - edited ā03-07-2019 05:44 PM
Can anybody explain me the difference between below model switches & what feature the X model switch support which S model don not.
ws-c2960s-24ts-l
ws-c2960X-24ts-l
Wajid Dabir
ā01-22-2014 09:36 PM
Your best bet is to check the data sheet.
Cisco Catalyst 2960-X
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12995/data_sheet_c78-728232.html
Cisco Catalyst 2960-S
Please rate replies and mark question as "answered" if applicable.
ā01-22-2014 09:39 PM
The only difference i found is:
2960x supports:
Application visibility and capacity planning with integrated NetFlow-Lite
Lite Cisco IOS software features
Power resiliency with optional dual field-replaceable power supplies
Everything else is the same on two switches
ā01-23-2014 04:34 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
One significant difference would be FlexStack vs. FlexStack Plus
ā01-23-2014 07:01 AM
Hi Wajid,
The difference between the models you stated is so significant in terms of hardware and software, the catalyst 2960X is and enhanced version of the previous one, cat2060S. You can find all the difference in this 2960X Q&A link (go to table 2). Which also compare the 2960-XR, 2960-X, 2960-S and 2960.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12995/qa_c67-728348.html
Have a nice day.
Manuel
