Difference between version and mode
What is the difference between VTP Version 2 and VTP V2 mode?
I saw this when I execute "show vtp status" which shows the following;
VTP Version : 2
VTP V2 Mode : Disabled
TIA
2 ACCEPTED SOLUTIONS
Re: Difference between version and mode
i think it is that u r device is capable of running VTP version 2 but it is currently disbaled on the device.
Mahmood
Hi Medan,
The version on the first line shows that switch is capable and support VTP version 2 but MODE indicates the current version it is operating on and if it is disable means switch is curretly not working on VTP version 2.
Ankur
Mahmood
Hi Medan,
Ankur
That should explain it, thanks guys.
140
