Dinamic Routes
Im new to cisco routes, Im traing to configure a 1711 routes with a dsl 2wire routes, my problem is that Im able to ping anywhere in the routes, but when Im on my computer I can only ping the interfaces on the router but no the 2wire route that gives me access to the internet.
                                                              Cisco 1711        2wire
                          f0 192.168.200.1(Inside NAT)          e0 192.168.1.76( 2wire Nat)              192.168.1.254      (Internet)
My computer is getting ip addres 192.168.200.100 when I ping th 192.168.1.76 is fine, but when I try to ping the 192.168.1.254 does not work, Im assuming the cisco has activated a dinamic route from .76 to .254, but it is not work con someone tell me why_
Here is the router configuration
Router#show run
Building configuration...
Current configuration : 1183 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 25
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.200.1 192.168.200.100
ip dhcp pool DHCP-Server
   network 192.168.200.0 255.255.255.0
   default-router 192.168.200.1
   dns-server 201.144.127.241 200.33.148.210
ip cef
no ip ips deny-action ips-interface
no ftp-server write-enable
no crypto isakmp ccm
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Ethernet0
description wan interface
ip address dhcp
ip nat outside
ip virtual-reassembly
full-duplex
interface FastEthernet0
description LAN INTERFACE
ip address 192.168.200.1 255.255.255.0
ip nat inside
speed auto
router rip
network 192.168.1.0
ip classless
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit 192.168.200.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
end
Please help me thank you
  • LAN Switching and Routing
1 ACCEPTED SOLUTION
Purple
Dinamic Routes
this is not correct:
so do this:
router# clear ip nat translation *
router# conf t
router(config)# no ip nat inside source list 1 interface FastEthernet0 overload
router(config)#  ip nat inside source list 1 interface Ethernett0 overload
Don't forget to rate if helpful.
Regards.
Alain
Purple
Dinamic Routes
so do this:
router# conf t
Regards.
Alain
Dinamic Routes
Thank you
248
