Disable BPDU Filter
nouman_nabi
I want to disable BPDU filter and applied command "spanning-tree bpdufilter disable" under the interface but still I am getting following output that Bpdu filter is enabled internally.
sh spanning-tree interface FastEthernet0/1 detail
 Port 3 (FastEthernet0/1) of VLAN0001 is forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.3.
   Designated root has priority 32769, address 0019.2f4d.4580
   Designated bridge has priority 32769, address 0019.2f4d.4580
   Designated port id is 128.3, designated path cost 0
   Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 1
   Link type is point-to-point by default
   Bpdu filter is enabled internally   BPDU: sent 44, received 1
Please advise how it can be disabled.
Reza Sharifi
Can you try this command and test again?
no spanning-tree bpdufilter enable
nouman_nabi
Thanks Reza for reply but there is no difference.
after doing this command:
can you issue:
clear spanning-tree counters
and than watch to see if the counter increases.
currently is is at:
After cleared the interface counter I noticed BPDU sent counter was increasing so it looks like default behaviour of running IOS version.
