Disable logging on switch port/TACACS
We are implimenting TACACS on our network.
However we do not want to see when
a user ethernet port goes up or down on the switch..
How would this be implimented?
This is the current tacacs config
aaa new-model
aaa authentication login default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa accounting command 15 default start-stop tacacs+
service timestamps debug date
service timestamps log date
tacacs-server host 192.168.4.23
tacacs-server directed-request
username xxx priv 15 pass xxxx
enable-password xxxx
service password-enc
line vty 0 15
privil level 15
line con 0
privil level 15
Re: Disable logging on switch port/TACACS
You'll have to change your logging level (for trap).
RTR-7206VXR(config)#logging trap ?
<0-7> Logging severity level
alerts Immediate action needed (severity=1)
critical Critical conditions (severity=2)
debugging Debugging messages (severity=7)
emergencies System is unusable (severity=0)
errors Error conditions (severity=3)
informational Informational messages (severity=6)
notifications Normal but significant conditions (severity=5)
warnings Warning conditions (severity=4)
What is your current level? I think anything below 6 does not log up/down.
Hope that helps.
hmnm i think I am at 6
cat1.nyc4#show log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes,
0 overruns, xml disabled, filtering disabled)
Console logging: level debugging, 13629 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 13629 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Trap logging: level informational, 13632 message lines logged
I will try ur advice..thx
You could add the following interface command "no logging event link-status" on all your interfaces. This would allow you to keep your logging level and not see lines for each up/down on the switchports.
HTH,
Mark
Nice one Mark, I ever knew about that one.
Collin,
I discovered that one a while back and it is a very handy command to have especially on a port connected to an end user PC. It keeps the logs alot cleaner that way.
Thanks for the rating!
Mark
445
