12-14-2013 05:15 PM - edited 03-07-2019 05:05 PM
I've looked around for an answer for this specific issue but haven't been able to find one yet. Hoping this is easy and someone can point me in the right direction.
When logging into a 2950 switch via Telnet, I'm prompted for a password when attempting to "enable" privileged mode. I want to disable the password requirement for now (home lab, not production). When I initiate the "no enable password" or "no enable secret" command (via a console connection), and try to initiate the enable command, I receive the message "% No password set". If I now attempt to enable privileged mode from the console, I'm not asked for a password. How can I disable the password prompt for VTY mode?
Thanks!
Solved! Go to Solution.
12-15-2013 10:41 AM
Try creating a username also with 15 privileges.
username cisco privilege 15 secret cisco
12-14-2013 07:37 PM
Under the vty's add the following command
privilege level 15
12-15-2013 09:10 AM
Thanks for the suggestion; I've tried it but am still asked for a password.
From global config, I entered:
line vty 0 15
privilege level 15
exit
Am I missing any steps there?
Thanks!
12-15-2013 10:41 AM
12-15-2013 10:49 AM
That was it. Thanks for your help!
12-15-2013 10:48 AM
line vty 0 15
no login
privilege level 15
Alain
