Disabling Spanning-Tree Globally
davidhuynh5
Is there are way to disable spanning-tree globally on a cisco switch instead of per vlan? Can you provide the commmad? Why you ask..to bypass BPDUguard configured on another switch. Thanks in advance.
4 Accepted Solutions
kyukim
As you already, it is not recommended to turn STP off.
There is no global command to disable spanning tree globally.
But, you can disable all configured vlan by "no spanning-tree vlan 1-max vlan no of your vlans"
SW1(config)#no spanning-tree vlan 1-1014
SW1#sh span
*Mar  1 22:18:00.536: %SYS-5-CONFIG_I: Configured from console by console
SW1#sh span
SW1#sh spanning-tree
No spanning tree instance exists.
Hope this helps.
KK.
What is switch and IOS model.
If you are running a switch with CatOS model, the try this command
set spantree disable [vlan | all]
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/5.x/command/reference/setsn_su.html#wp1026808
Samy
Or apply BPDUfilter on all ports
Not recommending you do that, because that against the best practice; just want give you another option.
HTH,
Lei Tian
milan.kulik
Level 10
Level 10
wouldn't
spanning-tree bpdufilter enable
(see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_55_se/command/reference/cli3.html#wp1945458
for details)
be enough on the port connecting to the other switch?
HTH,
Milan
kyukim
SW1#sh span
SW1#sh span
Hope this helps.
KK.
Samy
HTH,
Lei Tian
milan.kulik
Level 10
Level 10
wouldn't
(see
for details)
HTH,
Milan
