Bronze
Disadvantages of running loopguard globally?
Is there any disadvantage of running loopguard globally with this command?
spanning-tree loopguard default
I've heard it should only be used on root and alternate ports.
1 REPLY
Re: Disadvantages of running loopguard globally?
Hello John,
Placement of global command is also related to the role of the bridge. The following link discusses the interaction of loop guard with other STP enhancements
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a0080094640.shtml
Padmanabhan
340
