DLSW and bridge with Catalyst 4500 Sup V
juanluis
is it possible to run dlsw in a catalyst 4500 with sup V or any other sup or module?.
9 Replies 9
Richard Burts
Juan
I do not have direct personal experience with this, so I checked the Feature Navigator on CCO. It indicates that with the IP PLUS or with Enterprise Plus feature sets that DLSW+ is supported on the 4500.
Rick
Rick
Thanks a lot. DO you mean that there is a ios i mage for the 4500 and sup V that support DLSW and bridge?
I have enter in the web but I dont find anything as you say. Could you send me the url, please?.
I need to confirm that this feature is avalaible, so I could open a case and ask the ios to cisco.
If you answer yes to my first question I will be a very happy man!
Juan Luis.
Juan Luis
What I find is not specific about the Sup V. But the feature navigator does say that this image c4500-js-mz.122-23.bin does have support for bridging between 802.1Q VLANs and does have support for DLSW+.
You can use the feature navigator at this URL:
www.cisco.com/go/fn
and it has options to check by feature, by platform, or by spacific image.
Rick
Rick
Are you sure this is for Catalyst 4500 with supervisor V?
In the feature navigator I don't find anything about your version for the catalyst 4500.
Juan Luis
Are you saying that you went to the Feature Navigator (at www.cisco.com/g/fn), that you selected the option to search for a particular release, that you specified image c4500-js-mz.122-23.bin and that it could not find this image?
Rick
Rick
Yes,
When I search a release selecting the Catalyst 4500 and sup V I dont find the file you say.
The file c4500-js-mz.122-23.bin is for Catalyst 4500 sup V or it is for router 4500?
If it is for catalyst, how or where can I get it?
Juan Luis.
Juan Luis
It appears that this image is indeed for the router 4500. my mistake. I appologize. Based on this I was incorrect to say that there was support for DLSW in the Cat4500. Having looked again I believe that DLSW is not supported on this platform.
Sorry
Rick
Rick
No problem
Thank you very much. I will use a external router to run dlsw.
I have 2 4506 and 2 routers and must work redundant, if it is not very umpleasant for you, I would like send you the configs so you can take a look and tell me if there is any mistake. You seem to know very much about this.
Thanks for all.
Juan Luis.
Juan Luis
If you send the configs I will take a look at them.
Rick
Rick
