DLSW with HSRP
Hi all,
is possible to terminate DLSW peer on HSRP address for redundancy?
Thank you very much
Diego
Hall of Fame Super Bronze
Re: DLSW with HSRP
Diego,
I'm afraid not, if you want redundancy with DLSW, please see
http://www.cisco.com/en/US/tech/tk331/tk336/technologies_configuration_example09186a0080093ecc.shtml
Re: DLSW with HSRP
Edison,
It's been awhile, is your answer still true? I set this up in a lab I have at home and it appears to work. While I don't have any SNA boxes to really test it, the DLSw peers do connect and if I cause an HSRP failover, the "new" peer connects after about 20 - 30 seconds and the old one times out after about 1 minute. I am running 12.3 on the 3640s I have set up as HSRP peers. Maybe the newer IOS version enabled something to work that didn't in earlier versions?
DLSW with HSRP
Is there an update on this issue ? Pls. help me. I am going to attempt this.
Bronze
DLSW with HSRP
using the hsrp virtual address as a dlsw local peer address is not (and will never be) supported. Matthew
338
