Dmvpn help
Hi, sorry for my little eng
You help me?
where is my error
my conf for hub is :
Current configuration : 1703 bytes
version 12.4
hostname Gropello
boot-start-marker
boot-end-marker
enable secret 5 $1$hNMo$gMcGQbB1WFoD4AF9F3bH61
enable password MIm80799
no aaa new-model
resource policy
ip cef
voice-card 0
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp key mim80799 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
 mode transport
crypto ipsec profile SDM_Profile1
 set transform-set ESP-3DES-SHA
interface Tunnel0
 bandwidth 1000
 ip address 192.168.100.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 no ip next-hop-self eigrp 90
 ip nhrp authentication DMVPN_NW
 ip nhrp map multicast dynamic
 ip nhrp network-id 100000
 ip nhrp holdtime 360
 ip tcp adjust-mss 1360
 no ip split-horizon eigrp 90
 delay 1000
 tunnel source FastEthernet0/0
 tunnel mode gre multipoint
 tunnel key 100000
 tunnel protection ipsec profile SDM_Profile1
interface FastEthernet0/0
 description $ETH-LAN$
 ip address 37.159.205.66 255.255.255.252
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.17.2 255.255.255.0
 speed auto
 half-duplex
 no mop enabled
router eigrp 90
 network 192.168.17.0
 network 192.168.20.0
 network 192.168.100.0
 no auto-summary
ip route 0.0.0.0 0.0.0.0 37.159.205.65
ip http server
no ip http secure-server
snmp-server community public RO
control-plane
gatekeeper
 shutdown
line con 0
line aux 0
line vty 0 4
 password mim80799
 login
scheduler allocate 20000 1000
end
and for spoke is :
Current configuration : 1676 bytes
version 12.4
hostname Echo
boot-start-marker
boot-end-marker
enable secret 5 $1$VCZv$/lKOKw/.gFIYVMOxu31Mc/
no aaa new-model
ip cef
 encr 3des
 group 2
 mode transport
interface Tunnel0
 bandwidth 1000
 ip address 192.168.100.2 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp map multicast 37.159.205.66
 ip nhrp map 192.168.100.1 37.159.205.66
 ip nhrp nhs 192.168.100.1
 ip nhrp cache non-authoritative
 delay 1000
 tunnel source FastEthernet0/1
 tunnel key 100000
 ip address 91.81.10.74 255.255.255.248
 duplex auto
 speed auto
 ip address 192.168.20.2 255.255.255.0
 speed auto
 half-duplex
 no mop enabled
router eigrp 90
 no auto-summary
ip route 0.0.0.0 0.0.0.0 37.159.205.66
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
 password mim80799
 login
end
Best regard
Roberto
  • LAN Switching and Routing
On the spoke router, The
On the spoke router, The tunnel source interface should be F0/0 rather than F0/1 that you have there, also not sure why you have default route pointing to the Hub router interface IP on the spoke.
Manish
fantastic but now I have this
fantastic but now I have this problem:
IP-EIGRP(Default-IP-Routing-Table:90): Neighbor 192.168.20.2 not on common subnet for FastEthernet0/1
how to properly configure the routing-table bearing in mind that the IP addresses of the internal network can not edit it?
Thanks you're a big
Remove the "network 192.168
Remove the "network 192.168.20.0" from Hub router EIGRP config and "network 192.168.17.0" from the Spoke router EIGRP config. These subnets will be advertised by EIGRP automatically.
Manish
Errata corrige sorry but not
Errata corrige sorry but not work.
please help me
hi, Are you still having
hi,
Are you still having problem with 192.168.20.0 not on common subnet?
Please check on any neighbor that directly connected to this device to see if they're on same subnet. I had this issue before when one of the interfaces on my layer-3 switch connected to a router that was on a different subnet.
Wish you luck,
John
http://www.peakipsolutions.com/easyblog/categories/listings/it-blog
81
