DMVPN Routing Issue
This is also a re-post from another category. I appreciate any help.
We've been having some problems with the DMVPN implementation with one way calls from remote users to remote user voip phone. When I log into the remote-user 881s, I see routes for some of the other remote 881s missing.
We have two DMVPN headend routers at two different locations. The headend routers are using EIGRP - same as the remote routers but, the internal network that the DMVPN routers connect to is running ospf. The redistribution seems to be configured correctly between the DMVPN routers and the internal ospf routers. I see all the routes in the internal network routers and the DMVPN routers but, for whatever reason, the remote 881s aren't getting all the routes. Any ideas where I should look?
One of the remote routers that seems to have all the routes is configured with the whole range of it's subnets for instance:
router eigrp 100
network 10.1.0.0 0.0.3.255 (tunnel0)
network 172..16.5.80 0.0.0.7 (remote LAN)
network 172.22.64.0 0.0.3.255 (tunnel 1)
Ones that are not getting all the routes are configured as such:
router eigrp 100
distribute-list dmvpn_acl out
network 10.1.68.13 0.0.0.0 (tunnel0)
network 172.16.5.89 0.0.0.0 (remote LAN)
network 172.22.64.13 0.0.0.0 (tunnel 1)
standard IP access-list dmvpn_acl
10 permit 172.16.5.88 wildcard bits 0.0.0.7
I would think the access-list would make up for the host routes in thre eigrp config?
Thanks, Pat.
Everyone's tags (3)
359
