Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
DNS blocking on a 4500 core switch
We have run a 4500 core switch for about a year in one of our buildings. It is part of a larger active directory network. None of the computers in the building will show up in network neighborhood. They will show up inside the building though. Our dns is run by our parent forest organization and even their DC will not show up outside the building.
This is an issue as many programs use that to do their work. Trying to add by ip address which does work is a pain.
thanks
Gary
Hall of Fame Super Bronze
Re: DNS blocking on a 4500 core switch
Please post configs.
If I remember right, the "network neighborhood" is NETBIOS based which uses broadcasts. Try using a WINS server. I honestly haven't used the network neighborhood for sometime now.
When accessing other pc's by name, try using:
\\machinename.domain.xyz
If you have the dns suffix settings in windows as "domain.xyz" you should be able to access computer's via machine name only (\\machinename)
DNS suffix can be pushed out via DHCP
Your winxp/2k machines should dynamically update the DNS records too.
hth,
Ted
Where this comes into play for example is using the remote shutdown utility. It gives you the same list that you see when you browse network neighborhood. This is used by backup exec when browsing for other servers to backup. It is used by Scriptlogic when looking for DC's and so forth.
From the building itself I can see the other building's computers but outside the building I cannot see the computers back in.
thanks
Gary
193
