11-19-2011 07:57 AM - edited 03-07-2019 03:29 AM
When purchasing part number WS-C3560X-48P-L is a StackWise cable included or do I need to purchase that separately?
11-19-2011 07:59 AM
The cable comes with the package. It is in the box when you get the switch
11-19-2011 08:08 AM
the 3560 is not stackable only 3750 (It comes in the box)
11-19-2011 01:00 PM
The 3750X stackable switches come with a 0.5m StackWise cable by default.
Both the old style 3560 and newer 3560X switches are not stackable
See the hardware installation guide here which states:
The Catalyst 3750-X switches support stacking through Cisco StackWise technology and power management through StackPower. The Catalyst 3560-X switches do not support switch stacking or StackPower.
and
Length of cable. Depending on the configurations that you have, you might need different-sized cables. If you do not specify the length of the StackWise cable, the 0.5-meter cable is supplied. If you need the 1-meter cable or the 3-meter cable, you can order it from your Cisco supplier. For cable part numbers, see the "StackWise Ports" section on page 1-19 . The "Data Stack Cabling Configurations" section provides examples of recommended configurations.
Hope this helps.
