do we have any issues if we enable automatic erro dsable recovery on switch
Do we have any issues when we enable automatic error recovery enabled on a switches port.
does some one know any kinda issue when we enable that on a port which might cause a link to come back after time interval and does this bring a link to go bad?
Thnx
1 ACCEPTED SOLUTION
Purple
Re: do we have any issues if we enable automatic erro dsable rec
There is no problem using it but you have to remember that the error did not just happen by itself and probably will not go away by itself and should be investigating as to why the link is flapping or whatever the err-disable error is . It would not make a link go bad , if its causing an error there is already some type of problem on the link.
Purple
Thank u so much
94
