Community Member
Does 2691 Router supports 3 - WIC-1DSU-T1- Cards?
Hi all,
My 2691 Router has already 2 serial cards WIC-1DSU-T1 installed,
When i install the 3rd serial card and reboot the router, it detects the 3rd card  installed but 3rd card has no light.
When i do sh ver  it shows 3 cards installed.
When i install this 3rd serial card to other Router  then light shows on card and it works fine
So i am thinking if 2691 Router only supports 2 serial cards?
MAhesh
1 ACCEPTED SOLUTION
VIP Super Bronze
Hi Mahesh,
The 2651 supports 3 WICs.  Have a look at table-1 in this link:
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd800fa5be.html
Then go to table-7 and see if you have the correct IOS installed.
What is the model of your other router?
Reza
VIP Super Bronze
Hi Mahesh,
Reza
Community Member
Hi Reza,
Thanks for reply.
Other Router is 2650 XM.
I am plugging back 3rd WIC card to 2691 and reboot the the router to see if it works now.
As per link which you send me it says that 2691 supports 3 WIC cards.
I have right IOS on 2691 C2691-ADVIPSERVICESK9-M), Version 12.4(25d) -- it should support 3 WIC cards.
I will  update you soon.
MAhesh
Community Member
Hi Reza,
Reseating the WIC card worked.
Thanks again
Mahesh
398
